Anyone know why we have Stalled file from WU and our history and reports are not working
www.favershamweather.org
Hi FavWeather,
The DNS server of your provider seems to have a problem.
Better contact the hosting support and let them check their DNS server.
This is the full URL the PWS_load_files.php script uses to load the forecast.
https://api.weather.com/v3/wx/forecast/daily/5day?geocode=51.31,0.88&format=json&units=h&language=en-GB&apiKey=API_SETTING
When running it in the browser, the WU site is found and returns correctly “message”:“Invalid apiKey.”
If you replace API_SETTING
with your WU API-key the data will be correct.
So the link to the data is correct.
The PWS_load_files.php script returns the following messages when it tries to load the WU-forecast:
PWS_load_files.php (505) WU_forecast___: time spent: 0.056 -
→ invalid CURL Could not resolve host: api.weather.com
Also the scripts to load the WU historical data returns the same errors
The data in the files contain error messages.
That is why your graphs in temp-block a.s.o. do not work either.
I tested on other sites, no problems occur. All forecast, current and history data is up to date and the files contain valid data.
