Some of the NWS forecast icons in the template do not show up. I had moved some files and must have inadvertently caused the problem and haven’t been able to remedy it. Any ideas on what might fix this? Thank you. Bill
Go to Ken’s website (Saratoga-Weather.org - Home / Forecast)
there is a download for the icons with instructions.
Just a guess: when you moved the files did you move/reinstate the /forecast sub-directory as well? That contains specific forecast images and icons.
Ken mentioned the necessary directories here.
dcrooks & bitsostring, thanks. I have all the directories Ken mentioned listed in the saratoga/ directory on the server. Everything on the site appears to be working OK except some of the NWS icons don’t show, just “n/a”.
Reupload all the files in forecast/images directory from the icons .zip file to ./forecast/images directory on your website.
also looks like you are missing images-saratoga/Banner3.png
All the NWS icons are now showing after the reload. Thanks. But now the sun/moonphase icons in wxastronomy.php are not showing. I reloaded that file but no success. blainec - Banner heading is back. I was trying out a photo in the banner to see how it looked. --Bill T.
But there seem to be icons and svgs missing all over the template:
And if I go to your PWS dashboard from the link on the template I get a double header, and sometimes a second copy of the whole dashboard below the footer:
I don’t get that when I go from your main page. . .
Yes, I see that. I removed the link for now. The links to my other 2 sites work OK. Some of the icons seem to appear then disappear. The biggest challenge with the template for me is getting directories/folders/files in the right place using the Control Panel, a combination I suppose of lack of knowledge and experience. I think that is why I’m having the icon problems. I’ll keep working on it. Bill T.
After some adjustments in files, the site seems to be working well right now. The astronomy icons are back. The only disfunction I can spot is that the current conditions icon shows but then disappears, so I will have to monitor that. If anyone has an idea why that would occur, I’d welcome hearing it. Also, I reinstalled the link to my PWS Dashboard site, and it is working OK. Thanks to all who posted in this thread for helping me out. Bill T.
Current conditions icon is in /ajax-images too. Might be worth re-uploading a clean copy of that subdirectory from the zip.
Current conditions icon looks OK now?
Yes, it is showing consistently now. Not sure what the problem was.
