[solved] No longer posting to CWOP or WU after moving WD to new machine
I have recently changed my weather server to a new machine with a very similar hardware configuration and the same OS. Since doing the move, it seems my CWOP & Weatherunderground page is no longer updating.
Heres what I have done before moving WD to the new machine.
  • Copied my Weather Display directory to the new machine (same drive assignments)
  • Ran the “databackup/wdisplayftp.reg” file.
  • Restarted WD, and made sure it worked and all my settings were intact and that WD updated necessary webfiles.
I went back and checked the CWOP & Weatherunderground settings, and they are all properly set.
So, are there any files that need to me copied over or did I completely miss something? I still have access to the old server drive images.
OS: Windows Server 2003
WD Version: 10.37P-(b30)
Hardware: Proliant DL360 G2 (previous machine was DL380 G2) 4GB RAM
Thanks for any help. :slight_smile:
Did you run the WD install?
Actually, No I didnt run the WD installer… I’ll give it a shot and update the post if it works.
I followed the directions located in the WD FAQ on moving to a new machine.
Update:
Reinstalling WD seemed to fix it. I’m posting data to both locations now… :slight_smile:
Thanks niko
walks off with the dunce hat
