Solar sensor problems
Whilst running the last few recent versions of WD I have had a strange intermittent fault with my jam jar solar sensor. I was wondering whether anyone else had had the same problem and knew how to fix it.
The solar % switches every few minutes between the correct reading (100% for today as its nice and sunny) and 0%. This results in a very spikey graph. The jam jar temperature is coming through OK, and is displayed correctly when I look at the reading in WD via view>WMR extra sensors. The problem must be something to do with the solar sensor settings under control panel. The lastest 6 hour graph shows the problem http://www.paulwilman.com/curr6hourgraph.jpg
Paul
