Solar Reporting weird
When turning on the ability to show Solar in the summary image, the word SOLAR shows up much larger than the rest of the text.
Not sure if there is somewhere to change that but it appears that the text settings should be the same as the rest of the labels.
i have seen that…
email me your settings:
go action, back up registry entry now, then email me the files, wdsiplayftp.reg and wdisplay.ini from the databack up folder
which version of wd?
I uploaded the version you spoke of and after having a tad bit of trouble with the baud rate again… it has settled down and now the Summary display now looks better though I didn’t change anything…
Which I then adjusted a bit and now looks like:
just in from milking cows
i will loot at the settings re the baud rate, and check i have fixed it (i might not have uploaded that fix)…
restarting wd would have fixed that solar caption problem…i will see whats up there
Just in case you are chasing something that is not there… I changed the font colors on purpose and they look okay to me.
the green was intentional.
what i have done now is only hook in the font colour,and left the font type the default, for those 2 labels, now
in 10.17s
which will be ready soon (and which also fix the 2400 baud rate thing, i hope)
OK, I can’t seem to find where it is you turn on this solar for the summary image and change the fonts. Been looking and looking, please steer me to the obvious.
its in the setup, control panel, summary image and icon setup
