Solar percentages
I did something slightly silly… :oops:
When i first wired up my solar sensor and got readings from it I looked around in WD and while trying to set the “sunny”, “partly cloudy” etc settings, I adjusted the percentages, so the icons matched the actual weather.
I now understand that instead of doing that I should have adjusted the max mv so the percentage of that matched the icons…
… but now of course I don’t know what the default percentages were… can someone help please??
thanks
Daryll.
Daryll,
Not sure if this is what you are looking for… I have not adjusted mine so I assume these are default values.
Bill
