On the HTML page that is generated by WD with the statistics (#2 I beleive) it shows entries for UV and Solar minimums. Since this will always be zero (unless I am missing something), would it not be better to get rid of both of them and use the two spaces for something more meaningful?
I don’t know if you actually made any changes in this on 9.16 but the display of the data1htm.txt data is now somewhat broken.
If you look at my page at Http://www.mogur.com you’ll see what I mean with the UV and solar numbers. They are weirdly displayed and formatted now, where they were always fine before. Also, the trailing parenthesis is missing on all the “(since 0 hour” tags…
yes i did change it,
you did want the mimum uv…
but i will fix it up
i see you must have set up the summary image to not have the moon as separate image…and the default ioc is still visible, and the moon words nweed to go a bit lower
export and email me your wdisplayftp.ini file from the registry http://www.weather-display.com/exportregistry.html
It appears that what happened was that you removed the minimum UV but not the minimum Solar. Thus, the formatting is now weird with maximum UV displaying all on a line by itself in bold with the numbers run-on at the end of the line. Also, the trailing parenthesus is missing on the all the “(since 0 hour” labels. This is in the data1htm.txt generated table. Look at http://www.mogur.com and you’ll see what I mean.
How does one setup the summary image to have the moon as a seperate image as you mentioned? I can’t find that in the setup screens.
If they will display side by side where the one image is currently, that would be nice. What happens during the day when there is no moon?
One other thing: When it is clearly night time (you know this from the time of day and/or the sunrise/sunset times), perhaps the “Current Sky” field should say “Night Time” rather than “night or fog/dust…”
Thanks!
Tom
yes i did change it,,,
you did want the mimum uv...
but i will fix it up :)
If you look at my weather page toward the bottom of the text summary page just below the scrolling forecast, you’ll see that Minimum Solar is still there (it should be gone), that Maximum UV is on a line by itself and in bold, and that the trailing parenthesis is missing on all the “since 0 hour” labels. I am using IE 6.0, does it look different on your browser?
Thanks!
Tom
P.S. I checked the seperate sun/moon icons box. Thanks!
setup, summary image setup
tick have the sun moon as a separate image
i did do a test of the UV thing tom, and i couldnt duplicate what you see, but i will retry…
