Solar and UV have stopped showing but only in WD
About 2 weeks ago WD 10.37h has stopped taking UV and solar readings on my Davis VP1. This has been working fine for years. The option is ticked in station setup and all other readings are fine. I have removed the options and readded them. The console shows the readings and even weatherlink will show the readings fine so it is almost certainly a WD problem. I have restarted both the machine and WD loads of times.
Any ideas?
Mine is working fine for solar (I dont have a UV) but I’m on 37k build 00. I have had no problems at all with solar for ages now, so I’m hard pressed to see that its a WD problem. You could install a new copy in a separate folder (I’m sure there’s an FAQ on that) and then see if it collects the data, if it does then you have a settings problem somewhere.
FAQ is here
Upgraded to 37k and it seems to have fixed it, all working fine again.
