prob with special/vp graphs in 10.37q(incl build 58). 2nd moisture graph is wrong and get strange graphs if one changes the timescale. using davis vp2
tom
tom
could you be a bit more specific/provide more detailed info/screen shots?
its a bit hard to know exactly what you are refering to
thanks
Sorry Brian
When I try to view any 2nd soil moisture graph I get the same graph(attached)(tried over a few weeks, its an identical erroneous graph, the high moisture at the start never ages… This is a screen capture of 7 day soil moisture 2, if I switch to any other timescale, I get the same graph and and the x axis title is incorrect.
tom
ah
try a new .zip update, ready now
Brian
not sure if Im picking up the correct .zip. Went to downloads and downloaded "Version on 27 July 2011 - 03:47:39
". still get the same problem, first display(soil moisture 1) is correct, change timeframe to 7days, its correct, after that I try soil moisture 2, wrong graph(the one I attached above), change time frame, incorrect graphs, change back to soil moisture 1, incorrect graphs, Back out to main window then try again, exactly same results/graphs sequence.
tom
I will need your data files…
monthextravp72011.inf data file
Brian
Unfortunately it exceeds the forum limit for upload, even when zipped. It’s currently 1.6MB. Is there an alternative upload location??
tom
Brian
Don’t know if it helps, but I went back and reinstalled v10.37P build 44 from the board and the problem disappeared, both soil moisture probes are accurately displayed and the time period buttons function as one would expect.
tom
Brian Unfortunately it exceeds the forum limit for upload, even when zipped. It's currently 1.6MB. Is there an alternative upload location??
I meant to .zip and email me them
on its way
you need to zip the file first (see my post above)
as it was removed as sunsafe from the email
same result on 59 as 58
I do not have the needed correct file though
so can not work on this
you sent me the wrong file
Fixed in Build 60
thanks Brian
yes, I had forgoten to add code to delete the data already there before re drawing new data
with the updated graphing component
