Brian,
Note the graph
http://www.jlocon.com/snowdetail.gif
Any chances of getting this repaired to reflect inches plus getting the Seasonal snow correct?
Tks…
Brian,
Note the graph
Tks…
i have this OK now
(tested too)
I had only done it for loading older months recors, you see
uploading a new 10.20L now to fix this
Updated to the “L” version:
Partially there. The numbers on the far right are showing 10,20,30,40 - hopefully there’s a missing decimal point as the daily wasn’t 30 inches.
Also, the Snow this Season is still ----
email me your settings and data:
wdisplayftp.reg, from the folder databackup, after going action, back up registry entry now
and the log file 122004lg2.txt
so i can fix
oh and yes there was a units (x10) conversion mistake, but i did spot and fix that,honest,so maybe try downloading a new 10.20L…but i am not sure if its there as i cant get to the server yet
Brian,
Files have been e-mailed.
OK on the latest “L” version. Will check back agian later.
found the bug with the season to date snow on the snowdetail not showing…
it was a spelling mistake with the reading of the ini file…
it was ok for if metric units was in use in WD
will upload 10.20m now, now that I see the wd server is back up again
