Slight problem with metar.gif images
I thought it would be nice to have more than just one local metar on my site so I set the METAR download to receive data from Inverness, Stornoway, Benbecula and Tiree.
This is being downloaded with no problems and I have the correct names set in the metar sceeen of WD. But when I display the meter screens in WD I only get Stornoway (the main one), Benbecula (with no colour adjustments at the top of the screen) and Inverness.
Now, the Inverness screen has a scroll box in the bottom right hand corner with all the .met files listed in it but, no matter which one I click on, the title on the screen stays the same. The data changes to the correct metar but not the title.
Here are the four screens so you can see what I’m on about:
Anyone got any ideas how to get the name to change?
I’m at work just now so if I need to check anything it’ll have to wait until the morning.
Cheers,
Martin.
ah,must be a bug
i will test/check it out
Cheers Brian,
I’m still using 10.37f build 4 if that helps any.
Not had the need to update of late, although I’ll be taking the system down tomorrow to fit the new anemometer, move lightning detector and temp sensors so I may as well update while I’m working on that lot. :wink:
ok, i see a that the problem will occur if you have set to use a name replacement for the airport
I had code in place to deal with that, but I had > around the wrong way
next update of wd should fix this
Thanks Brian,
Glad it was an easy find & fix. :thumbright:
Thanks Brian,
I’ve just downloaded the latest update (10.37f build 13) and it’s working fine. :smiley:
