Site check please
Just switched firewalls and lost my IP address.
Would someone check www.msweather.net and, if that’s resolved by your DNS yet, try http://68.194.193.175:8082 to see if my site comes up. Note it’s the .net site, not the .org site, which was not affected.
If it does, please try the motion bee cam under the “Webcams” menu, as that is using a different port and I need to see that I have the firewall configured to pass the requests through correctly. (It’s dark here, so you likely won’t get a good image)
Chris
I can get to both your sites here, however am getting no data on the live "beecam"from either site. Hope this helps.
Cheers
Nice site. How do you do the moon info table?
OK, thanks. Hope the beecam issue is just because it’s dark. Is there a time stamp at the top of the image? My firewall prevents me from seeing my local hosting appliance.
Nikoshepard, just click on the globe and it will take you to where you can d/l the script for the moon phases.
Beecam Status via the IP address and URL
X10 beecam = two images, time stamp at bottom of both changes with mouseover
Amazing/live video/fullscreen beecams = not finding image
Thanks for the moon info, I’ll check it out tomorrow.
Yep, did spot an error in my source code when I put in the new IP. Hopefully the Axis Cam is working now, as I’m out of here for the weekend.
Thanks for the assist.
