Apologies for the few short outages today.
I’m still learning how to drive this new environment and after applying a number of upgrades I found a problem. The database is accessed via a load balancer…basically you connect to a defined port on any active node any you’ll access the same database. Unfortunately when I set the load balancer up I forgot to set it to restart after a reboot, so things went a little whacky for a while. I’ve resolved the problem now so that’s one less problem to come back to bite me again!
