Can anyone tell me if it
WD’s webcamcapture can handle 2 camera’s
but only one can be streamed
Hi Brian! Thanks for the reply! If I only set up one camera on WD will it allow me to both stream and upload a still image to the webpage on a timed schedule? If it’ll do that I can use WD to run the birdhouse camera and use Tincam or another installation of WD on a different computer to run a weather cam. Again, thanks for the reply. And, BTW, great software and simply amazing support you provide.
If I only set up one camera on WD will it allow me to both stream and upload a still image to the webpage on a timed schedule?yes, you should be able to set it up to do that OK
