See in the error log an error about the "_test.php" file
See in the error log an error about the “_test.php” file.
Error.log:
PHP Parse error: syntax error, unexpected identifier “ini_set” in /home/meteocul/public_html/pwsWD/_test.php on line 7
Both files added as attachment.
_test.php:
Line 7: ini_set(‘display_errors’, ‘On’);
Greetings Arie
www.meteo24-culemborg.nl/pwsWD/
_test.zip (1.0 KB)
Solution here:
https://discourse2.weather-watch.com/t/found-an-error/70847/8?u=pwsdashboard
Have a lot of small problems also with some scripts.
Will try to rollout a new update soon
