Searching for variables
Hello!
To allow weather-display to work with the spanish network from automatic stations at
http://www.meteoclimatic.com/sitmap.asp
(click on the map to see something)
I’m searching for some variables, see
http://www.casacota.net/meteo/wx4.html
I’ve nothing found in for those data at wdfulldata.htm and I need that:
Year to date:
max temp celsius, min temp celsius, max humidity, min humidity, max barometer, min barometer, max gust, max dexpoint and min dewpoint. I guess there are no variables defined or specified in wdfulldata?
It would be also usefull to have variables for max rainrate/min for the last 24 hours, month to date and year to date.
On the other side, if time is in 24 hour format, AM/PM is also displayed.
Maybe I’ve not found the correct variables… can someone help? Thanks!
Still nothing found - maybe I’m asking for something obvious?
I’m also unable to ask Brian by mail, since my network seems to be blacklisted at the weather-display mail server (although SFP enabled) :frowning:
Please, if someone can confirm that the asked variables are not working or that I’m
most of the tags you are looking for may be in this list??
for current year to date:
%yrecordhightemp%…All time record high temperature
%yrecordlowtemp%…All time record low temperature
%yrecordwindgust%…All time record high wind gust
%yrecordwindspeed%…All time record high average speed
%yrecorddailyrain%…All time record daily rain
%yrecordlowchill%…All time record low windchill
%yrecordlowchillhour%…All time record low windchill, hour
%yrecordlowchillminute%…All time record low windchill, minute
%yrecordhighbaro%…All time record high barometer
%yrecordlowbaro%…All time record low barometer
I don’t think there are any tags for year to date dew point (Punto de roc
Thank you very much for your reply!
You write:
Is that right, that the “all time” records are concerning only “year to date”? If yes, the problem is solved! My records are not very old, so I cannot find this out, but I need to know this to release a template to other meteoclimatic-WD users that should not be changed in the future.
Thanks again!
Cordialment, Pere
hi, yes,try adding those custom tags to the raw template wdfulldata.htm
sorry I missed this post, and it does seem i dont get the emails …
Thank you very much!
There are now only 2 pairs missing to match the template from meteoclimatic (see http://www.casacota.net/meteo/wx4.html): the year to date max and min humidity and year to date max and min dewpoint (in C
I have another related problem with these tags: the results are displaying also the units, and are unsuitable for the robots that collect the data.
Eg: http://casacota.net/meteo/wxlocal3.html produces http://casacota.net/meteo/wx3.html , with the units, and also the time format in 24 hr. format has AM/PM…
It would be great to solve these small issues.
Thanks Brian for all the great work!
try:
go to setup, control panel, ftp .internet setup, custom web page setup
and untick, include the units used
i have not added all time record high humidity, because for most people it will be 100%
(and then becuase i did not add that, there is no record low)
i could look at adding dew point all time records
Thank you very much, that’s it!
Yes, Please! :smiley:
And while I agree about the humidity max, it would be nice to see the low humidity.
