My data for july is screwed up. I had to do a system restore and for some reason it screws the data. Doesn’t screw the email but data it does.
is there any way to correct this rather than line by line? i thought there used to be a way to get at the data itself, then do the corrections and dump it back in its folder,
well, i have never used system restore…windows 2000 does not have it, but i have never had the need to
i dont know how it even works, and why it stuffs up wd data so much
you can open up the logfile, say 72004lg.txt
stright into notepad.exe
and edit there
and then save and then do the convert wd logfiles to graphs (see underr action)
maybe back up wd’s data before doing a system restore
System restore is kind of like Goback. If a piece of software installed or a bad driver, it allows a limited number of time s to go back before the install. But then every thing changes.
