Scale user-editable
Could you make the scales editable by the user (like you already did with the graphs). So I can adjust the weather dials’ scales to a fixed value(temp, rain, wind, etc)
Thanks!
you mean set a maximum range?
yes, i could do that…
Yes, by example: in the weather dials the temperature range is between -20 and 30
i have added ability to set the range for the individual dial images now, in the custom web page setup, in the ftp/internet setup
let me know,.,…
but i also need to add a similar setup like this for use with the weather dials screen dials too :slight_smile:
Works great Brian. :thumbright: Thanks again!
Greetz,
Koen
in another new 10.10o, ready now, you can now also set the scale range of the weather dials too
see the new button on the units setup, bottom left hand side
Ok, I found the button :slight_smile:
The daily rainfall scale resets itselves after the next udate to the auto scale (again from 0 to 50 mm). The rest works fine. Can you also add a user defined scale for the hourly rain too?
Thanks a lot!
Greetz,
Koen
oops, i must have missed doing that one
was too late at night
No problem :lol:
I tested the latest version but the scale still changes to the default value after the next update of the values. I also didn’t find the possibility to set a scale for the hourly rainfall. Didn’t you got the time yet (no problem with that, I know you have more things to do) or is this still a bug?
Greetz,
Koen
