Hi Brian
on my main unit the extrarealtimegraph is having a problem with its scale lines on the right of graph most have disappeared as can be seen below
any idea why?
Hi Brian
any idea why?
any idea why? its ok on my backup unitits becauase i have them too close together.....and when you move the mouse over, it wipes them with the cursor position i will move them apart a bit..
also any idea why the icons on the right at the top of the main screen next to the minimise close icons keep disappearing, this happens on both units
its XP thing…with makes the icons biggger,
and the font size on the windows bar for WD is larger in XP too, and so with the weather conditions reported there, it wipes out those buttons
its not an issue with windows 2000 or if you can set xp to classic style, but in wd, extra and misc, you can disable the conditions in the window title bar to stop that
that sorted it thanks
