Moved from PWS_dashboard to a new topic to get more attention
Hi Ken,
got these errors , has this to do with the new files ?
(At this moment my index page page is empty donât know if this has to do with this problem )
[Sat Oct 21 07:07:54.099860 2023] [proxy_fcgi:error] [pid 30513:tid 140139858675456] [client 94.226.99.37:38624] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php:393\nStack trace:\n#0 /var/www/vhosts/matar.be/httpdocs/weather/index.php(58): include_once()\n#1 {main}\n thrown in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php on line 393'
[Sat Oct 21 07:14:39.589797 2023] [proxy_fcgi:error] [pid 41468:tid 140139959387904] [client 94.226.99.37:45820] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php:393\nStack trace:\n#0 /var/www/vhosts/matar.be/httpdocs/weather/index.php(58): include_once()\n#1 {main}\n thrown in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php on line 393'
[Sat Oct 21 07:14:41.825899 2023] [proxy_fcgi:error] [pid 41406:tid 140139883853568] [client 94.226.99.37:45848] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php:393\nStack trace:\n#0 /var/www/vhosts/matar.be/httpdocs/weather/index.php(58): include_once()\n#1 {main}\n thrown in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php on line 393'
[Sat Oct 21 07:15:08.250533 2023] [proxy_fcgi:error] [pid 41378:tid 140139833497344] [client 94.226.99.37:46072] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php:393\nStack trace:\n#0 /var/www/vhosts/matar.be/httpdocs/weather/index.php(58): include_once()\n#1 {main}\n thrown in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php on line 393'
[Sat Oct 21 11:42:58.530937 2023] [proxy_fcgi:error] [pid 4801:tid 140139841890048] [client 91.177.27.214:37884] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: array_key_exists(): Argument #2 ($array) must be of type array, null given in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php:393\nStack trace:\n#0 /var/www/vhosts/matar.be/httpdocs/weather/index.php(58): include_once()\n#1 {main}\n thrown in /var/www/vhosts/matar.be/httpdocs/weather/get-meteoalarm-warning-inc.php on line 393', referer: https://www.matar.be/pwsWD/index.php
Kind regards
Patrick
It is night in California, so for now:
Script get-meteoalarm-warning-inc.php line 393 reads currently
if (!array_key_exists(âwarningsâ, $array) || count($array[âwarningsâ]) < 1) {
change that to
if (!is_array( $array ) || !array_key_exists(âwarningsâ, $array) || count($array[âwarningsâ]) < 1) {
that will solve it for now.
Thank you Wim to âact as a replacementâ for Ken.
It solves the problem and the index page shows again the normal content.
Patrick
Your index page shows also
No current alerts for: âAntwerpen (BE002); Brabant (BE004); Limburg (BE007)â.
But for now the area codes used for Antwerpen and Limburg are BE21 and BE22
Add those other codes to your current settings
Page Check for updates list the used area codes for each country. Belgium is a mess to be honest. They use old and new codes.
country | code | type | last used | areas |
BE | BE001 | ktrue | 0000-00-00 | Luxembourg |
BE | BE002 | ktrue | 0000-00-00 | Antwerpen |
BE | BE003 | ktrue | 0000-00-00 | Oost Vlaanderen |
BE | BE004 | EMMA_ID | 2023-10-21 | Brabant |
BE | BE005 | ktrue | 0000-00-00 | Hainaut |
BE | BE006 | ktrue | 0000-00-00 | Namur |
BE | BE007 | ktrue | 0000-00-00 | Limburg |
BE | BE008 | ktrue | 0000-00-00 | Liege |
BE | BE009 | ktrue | 0000-00-00 | West Vlaanderen |
BE | BE21 | NUTS2 | 2023-10-21 | Antwerpen |
BE | BE22 | NUTS2 | 2023-10-21 | Limburg |
BE | BE23 | NUTS2 | 2023-10-21 | Ostflandern |
BE | BE25 | NUTS2 | 2023-10-21 | Westflandern |
BE | BE32 | NUTS2 | 2023-10-21 | Hennegau |
BE | BE33 | NUTS2 | 2023-10-21 | LĂźttich |
BE | BE34 | NUTS2 | 2023-10-21 | Luxemburg |
BE | BE35 | NUTS2 | 2023-10-21 | NamĂźr |
BE | BE801 | EMMA_ID | 2023-10-21 | KĂźste |
Problem is, these codes are not in Kenâs meteoalarm-codenames.json so the template doesnât recognise the area names: âName not available forâ
The codes are in meteolarm-geocode-aliases.php:
'BE21|NUTS2' => 'BE002',
'BE22|NUTS2' => 'BE007',
but I donât know what that means.
WIm,
when I do that (use BE21 and BE22) I get some remarks :
Name not available forName not available for Name not available forName not available for
when I look at the page source
Name not available forName not available for<!-- get-meteoalarm-warning-inc: saved details to ./cache/meteoalarm-details.html file -->
Name not available forName not available for<!-- get-meteoalarm-warning-inc: saved summary to ./cache/meteoalarm-summary.html file -->
<!-- get-meteoalarm-warning-inc: begin ./cache/meteoalarm-summary.html -->
Apparently Antwerpen and Limburg are not recognized because the name is not diasplayed in the green line.
kr
Patrick
Hi Patrick,
Then you should not use BE21 and BE22
Also i see a strange characters in that script in the line you added (392-396)
$valid_data = true;
// if (!array_key_exists('warnings', $array) || count($array['warnings']) < 1) { gives error PN
if (!is_array( $array ) || !array_key_exists(�warnings�, $array) || count($array[�warnings�]) < 1) {
Better correct the strange characters in line line 396 from the old line 393 you commented as line 394.
My fault , I copy pasted from your message, probably not a good Idea, I corrected it manually.
Seems (?) ok now
I just looked at the spec for the CAP alerts from feeds.meteoalarm.org which says:
<geocode>
Info
Affected areas according to Meteoalarm specifications.
Syntax
<geocode>
<valueName>MeteoArea</valueName>
<value>{AreaCode}</value>
</geocode>
{AreaCode}
Affected areas according to Meteoalarm specifications (AreaKey).
The NUTS classification shall be used wherever possible. For other areas the "
[FIPS 10-4 region codes](http://www.meteoalarm.eu/mediawiki3/index.php/FIPS)" or the MeteoAlarm internal area codes(EMMA_ID) shall be used.
[Eurost at NUTS Nomenclature](http://epp.eurostat.ec.europa.eu/portal/page/portal/nuts_nomenclature/introduction)
Example Part Area
<area>
<areaDesc>Tirol</areaDesc>
<geocode>
<valueName>NUTS3</valueName>
<value>AT331</value>
</geocode>
</area>
Since theyâre using a mix of NUTS and EMMA_ID codes in the alerts, the lookup in meteolarm-geocode-aliases.php does allow conversion of NUTS2/3 IDs in the alert to map to the (sometimes old) EMMA_IDs used by meteoalarm.org from the old instance of meteoalarm.eu. WhewâŚ
The get-meteoalarm-warning-inc.php configuration should always use the EMMA_ID for the area and let the script do the conversion of NUTS2/3 to EMMA_ID.
Iâve done another update to remove the old UK0nn and UK1nn codes ⌠they seem to be reporting only the UK2nn and UK3nn EMMA_ID codes now
DâOh⌠I had not removed the UK0nn, UK1nn codes from the data file driving the mapâŚ
Now fixed and UK shows in imperial Purple too
Thanks for spotting the issue.
