WD Ver10.37S45
I have added my local tide graph image generated from wxtide to my WD main window and I wanted to update the graph hourly. To do this I thought I would use the Internet Settings > Manual Upload/Run a Program (see attached screenshot) by running the runtide.bat file at 59mins past every hour. It works if I press the ‘Run now’ button, however it never works for the times configured.
To verify this behavior I made a test batch file that logged the date and time stamp in a text file as follows:
echo %date% %time% >> test_timestamp.txt
I ran this for a few days and the results were the same i.e. worked when pressing the test button but doesn’t work with the configured times.
