Hi, i have a wmr300 which i use WD on a laptop always on, ive jsut built a rpi4 4g media / nas server and want to setup on that now because its on 24hrs a day anyway.
It I have full Rasp buster installed with desktop so would be nice to have the gui with it too.
Is there anyway to make this possible and instructions. I will create a how to with all this information and post on here after too.
you should be able to just set the station type needed in the config.txt (235) and it should hopefully work
(with the com port number set to U (ie usb port)
thanks for that, is there instructions? i dont really want the webserver if possible because omv uses port 80. I want it so it logs on the rpi and i can see it on the small touch display too.
now when i run i get looking for file /home/pi/consolewdfiles/outdata.txt
I created that text file and make it access / edit by anyone and restarted it and it still says the same.
My using is WMR300 if ive not mentioned before. Am i supposed to install a driver for it? if so where / how.
I appreciate your help.
pi@raspberrypi:~/consolewdfiles $ ./consolewd
Station type raw=235<
Station type =235
Weather station type is an wmr300
meteobridge user= <
meteobridge ip= 192.168.0.1<
meteobridge pass= <
Davis com method d
Davis time out 0
Davis time out allocated OK
OWW file location= ←
program location= /home/pi/consolewdfiles/<-
Davis VP IP data logger port= 22222<
Davis VP IP data logger IP= 192.168.2.3<-
Davis WLL IP= 192.168.0.15<-
GW1000IP IP= ←
Latitude= -25.3
Longitude= 152.8
Station name =Stuee
clientraw location =
Daily rain startup= 0.0
start up month rain found=0.0<-
Monthly rain startup= 0.0
Yearly rain startup= 0.0
wunderground username =
wunderground password =
wunderground utc =-5
Dir offset= 0
Barooffset= 0.0
Comport is USB to serial
Davis com method d
Yes Revb Davis VP
Davis rain gauge .01 inch
mysql username =
mysql server =
mysql databasename =
mysql tablename =
Will do mysql metric
mysql time interval = 300
cwop station id =
cwop call sign = -1 // -1 is default (you do not have a Ham call si
cwop latitude=
cwop longitude=
FTP server =
FTP username =
FTP port = 21
FTPremote dir =
Will do ftp passive
remote file =
FTP time interval = 60
wu =Y
Will save logfile
logfile metric
Custom file name = wx.html
Custom file name 2=
Custom file name 3=
Custom file name 4=
Custom file name 5=
Tag units in celsius
wind units = kts
baro metric= Y
rain metric= Y
Will run cron files
Custom log out = customlogout.txt
temp offset raw =<
hum offset raw =<
wmr300 channel =1
Modified rain gauge= <
WOW id=<-
WOW pass=<-
PWS id=<-
PWS pass=<-
windycom station# =
windycom API key =
windfinder id=<-
windfinder pass=<-
meteotemplatepass=<-
meteotemplateurl=<-
univeral update rate 2
weathercloud ID =
weathercloud key =
email username=
email password=
email server=
email sendto=
email from=
email hour=
email minute= weatherlink.com DID= weatherlink.com API= weatherlink.com USR= weatherlink.com PASS=
wunderground api key=
wunderground api station id=
utc hour=5
local hour=15 Weather Display vers WD_console_19.5
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks! www.weather-display.com
pi@raspberrypi:~/consolewdfiles $ lsusb
Bus 002 Device 002: ID 0bc2:ab26 Seagate RSS LLC Backup Plus Slim Portable Drive 1 TB
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0fde:ca08 Oregon Scientific
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
If use this program,then please consider sending a PayPal donation to info@weath er-display.com (Brian Hamilton)
Cannot connect to station: Operation not permitted
WMR300 opened OK
data read length ->-1
USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB dev ice is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open USBWrite USB device is not open data read length ->-1
Write Error :: Broken pipe
WMR300 opened OK
I do have a wmr300 here, but I could not get it to work on linux
I remember now (it was a few years ago now)
sorry to have wasted your time on this
if you had a different weather station type then it would work
