My 2310 weather station’s battery was running low. Because of that I had bogus rainfall readings yesterday and today.
I went to Action/View and Correct the log file/ rain totals and reset the totals to 0. The bogus rainfall is still showing up on the graph and also in the total for rainfall Yesterday.
yesterday rain:
go to setup, control panel, barometer offets and rainfall
there you can set a new yesterday rain amount (and todays rain amount), and click on set, then yes to save settings
for the graph, try, setup, graph setup, then correct the graph
then click then hold then release on the area of the graph to correct
then click on set start/end
then tick correct rain
then tick set to zero total daily rain
then click on save
if its more than 12 hours old
then use the graph history correction at the bottom
then use the retreive, then click on correct again, then save
that should work
