I noticed that in the monthly Average/Extreme reports there is a link to view a particular days graphs. For example May 1st would be 20040501.gif. When I try to access this it says file not found. Where in the WD program do I activate the creation of this gif file and how do I get it uploaded. I know I am missing something and it is probably quite simple.
Steve
Hi Steve,
welcome to the forum,
I have not seen the 1st of the month gif created for me either since I started running WD in February.
I think it is something to do with the monthly reset of data that needs tweaking - I have not reported it as I delete all these daily gifs anyway off of my server as I do not require them - I guess Brian can add it to his list of things to check though as it should be there really.
I certainly do not think you are alone in this and I don’t think there is anything to click on in WD itself to fix - unless someone can dramatically prove me wrong on this!
cheers
sounds like a bug i need to fix…
you can turn off those daily updating files bristol…in the web files upload setting tab, in the ftp/internet setup
aah yes been meaning to mention this… I get this uploaded where the first day of the month gif should be… eg
http://www.portunus.net.nz/weather/20040401.gif
for a few months now I think… if thats any help
ah, that wil be because the file name to upload does not match the file name created, and so the file sequence gets out of sequence
I will fix this, and some other end of month roll over problems soon
you can turn off those daily updating files bristol....in the web files upload setting tab, in the ftp/internet setup :)
so I can - cheers for that
