Hello All,
I’ve had this problem for 2 weeks and cannot get to the cause of it.Whenever I fire up WD no matter if it’s been off 5 minutes or 5 hours it initially loads up historical data from the 9/10/11 February before then loading up the data since last time WD was run.My weather station(WS3600) time and WD times are all synchronised and there appe #-oars no problem there.The data logger time in WD is also set to the correct time and even if I dial in a time and then shutdown WD and restart it still loads up 9/10/11 FEB first.This is very annoying as it upsets all my current days data ie lows and highs etc.
BLIMEY!..I thought someone might have experienced this problem beside me.Does anyone have any views on uninstalling WD and starting again or is this too drastic,I can think of no other solution .
Before doing an uninstall/reinstall, I’d try installing a second WD. You can run that as a test. See:http://discourse.weather-watch.com/t/10889 for instruction on installing a second WD on your PC. Make sure that your original WD program is completely closed first, (use task manager to see) before installing and running the second version.
Hello Cirrus,
Thanks for the suggestion I 'll probably go down that route I think and see what results I get.I thought perhaps the problem may have eradicated itself with the change of month, but it still persists.
