Recent Linux WD tar file corrupt
I have downloaded the recent Linux build [10.37Linux Build 332 Version on 5 February 2022 - 19:47:51] on two different Linux systems, and both are unable to un-tar the file.
“invalid compressed data–crc error”
“invalid compressed data–length error”
i will try uploading/recreating again
Thank you for the new upload. I was able to un-tar the new file.
I have then tested the install on 3 systems…
Ubuntu 21.10 : seems to work :slight_smile:
RHEL 7.9 : crashes :frowning:
RHEL 8.4 : crashes :frowning:
Unfortunately, I am required to use a RHEL distribution.
When running in RHEL, it initially loads then crashes after a few seconds with the following attached error:
Does anyone have any suggestions to get Weather Display running on a Rat Hat distribution?
its a permission problem with the default home location being root
(you need to change your default home location to not be root)
or
create a file called
newhomelocation.txt
with your non root path for WD documents
e.g
/yourname/Documents/
have that file where the main executable file is
there is another thread about this
Closed - Over 6 months since last post
