actyualy, i can get it by going view source on the main.svg…
stand by while i look
(but the wife wants me to do some housework
Wives are allways right, Brian!
:roll:
Cheers
H
i got past the error by changing the url in the default one, and running the svg.htm from here on my HD
but there are other problems.
it looks like the free hosting service is putting html code in with the clientraw.txt file with the http get procedure from the svg code
so you are stuffed
i will let you use a ftp server i have here for free if you like
It’s very kind of you, I thank you a lot. Yes, I accept your offer, let’s see this weather coming to real! (I was away for a while, as my wife is always right, too…) :oops:
Cheers
H
i have updated the svgextra.zip file
http://www.weather-display.com/downloads/svgextra.zip
which fixes the mismatched tag error that appears in the bottom info bar of the browser
(it was a missing …took me a while to find it!)
I looked everywhere for that! LOL :?
well, i knew it didnt occur in my real time mesomap
http://www.weather-display.com/windy/svgmesomap.htm
and so i just deleteded sections of code until it went away!
it was a missing in the units section, where I had all the labels being drawn
whew
if you want to add your web cam image to the real time viewer, just add the following code to the main.svg file (i.e the line where it has “animatedwebcam.gif” i.e replace that with the name of your web cam file
[code:1]
<g id="CurrentCondition" onclick="" style="&st3;&st4;&st7;">
<!--<text text-anchor="middle" x="548" y="278" fill="blue"> </text>-->
<image id="IcondImage" xlink:href="" opacity="1" x="460" y="238" width="42" height="32"/>
<image id="IcondImage" xlink:href="animatedwebcam.gif" opacity="1" x="445" y="300" width="70" height="60"/>
</g>
[/code:1]
Great, Brian!
Cheers
H
it works, but strangely the animatedwebcam image does not animate
but so instead just use say webcamimage.gif or what you have as the non animated web cam image file name
Brian, when I put in the new section of code, I get my icon gif but no picture of my cam picture. If I rename the web cam picture to webcamimage.gif I get your web cam picture.?
Brian, I got it to work. Great feature!
also, the max gust for the day in kmh needs to be shifted to the right a bit
do that here, i.e set the X=“385” after the id=“WGDKMH”, or download a new svgextra.zip as I have done that already…
[code:1]
style="&st3;&st9;&st7;
[/code:1]
Yes, I noticed it, but as I had to leave home for the week-end, I wanted to mention it today. However, thanks, Brian.
Cheers
H
Rick sent me some changes he made to the layout that look good, in a new svgextra.zip file
