Re: How to setup a Custom WAP page
excellent work!
i am very pleased to see someone take the time and effor to put up a help/tip
thanks!
the tag to show the time stamped graph is:
%filenamewapgraph%
i will have to add a station name tag
[gratuitous plug]
my custom WAP data is at http://www.martynhicks.co.uk/weather/wap/index.wml
it would be nice to get reports from others that have accessed it to make sure it works ok - it does for me on my Sony Ericsson T610
[/gratuitous plug]
A snapshot off my phone of your page is attached…
For those with WAP pages… this is a great emulator.
http://www.gelon.net/
Chaps…
Is there a way to set a different location for the wap page to be stored?
I’m hosting my site on the same PC as the weather station (so no ftp required) and I want the wap page to go into …/wap
Thanks… Ciemon
in 10.18y, ready soon, you can set to use a different director for the wap file
Thanks Windy,
Same question in two different places :expressionless:
so is it working?
(as I did not have time to actualy test)
I’ve not downloaded it…
I’ll go and have a hunt then let you know :slight_smile:
It would appear that it doesn’t work.
Whilst all the required input options are there, the information doesn’t appear to be saved.
After setting up the wap page’s directory, and ok’ing the page, then re-opening it, the previously setup options are back to the default of nothing.
Not my best description ever, hope it’s enough.
Thanks…
good news
i found some time to fix this
download a new zip version in about 1 hour from now, or when the download page says the time has changed
(and then reset up)
try this version
it should be ok for this different wap location ( i tested)
http://www.tokaanuskihire.co.nz/WeatherD.zip
(i.e unzip to where you have wd installed, but exit wd first)
