RAINWISE IP100 - CONNECTION
Brian
just started to use WD again (long storey), but having issues getting data from IP100. Screen shot shows how I have connected, id=s this correct?
Keith
Update
it has now received 1 nr item of data, however I think there is an error as its saying the outside temp is 13 dogs, when actually is only 1 deg.
Keith
Try ticking crc in use and it’s cc2000 data logger
13c is just the default temp for WD
Brian
still no data received after changes you suggest.
Keith
U can set WD to show debug data
currently the latest WD mac version uses curl to get the data
you would need to make sure that is installed
but we could try where I try a different way to get the data
in any case you can set the debug mode via
setup, advanced/misc, log the raw data
is there a file created called ipdata.txt? (in the data files folder)
i have made a change that might help in the latest update
it would be good though if you could answer my question?
hello?
Brian
appo,logoies for not answering, been away. have uploaded the latest version, all seems to be working. I will follow through the instructions, and send data. IP Data file attached.
Keith
ip100.txt (2.7 KB)
so its working now, or?
Brian
its working.
