I’ve searched for an answer as I’m sure there is one. However, I’ve just re-set up my weather station and WD. Last night I installed FreshWDL and the rainfall is in July rather than August. I didn’t have anything set up in July. I’ve checked WDL and everything seems as it should be.
I think the problem is lack of data you need WD to have at least 31 days of data for this to work correctly
As the data in the clientraw daily is not date related just day 1-31 it thinks day 1 is in your case is 5th august but because the graph thinks backwards ie day 31 is today and day 1 is in July currently hence the way you see it
So once you have more data that should correct itself
Ah. Makes sense. Many thanks.
