Rain gauge hops to 43mm @ every restart
Howdy.
Just updates to v 10.37R Build 281.
I noticed that @ every restart, Wd’s rain amount gets additional 43 point something mm of rain. This is seen in the graphs at same time when the program was restarted.
Otherwise the station measures rain just fine.
Windows/TFA-Nexus
are you sure you are using the very latest update to build 218?
as I did fix that problem (should be) with the rain from an Irox station on first start (the amount of jump is the weather stations rain value)
