I recently re-installed WDisplay and the December rainfall on WDlive graph has gone to zero.
If I check all the WD graphs and data the December 2010 rainfall data is OK.
Problem can be seen here:- http://www.monadh-ruadh.co.uk/NB/nblive.html and click on annual rainfall.
WD data can be seen here:- http://www.monadh-ruadh.co.uk/NB/weekrep.htm and select December 2010.
How do I get WD to send WDlive correct data?
set the correct needed rain total
under
view,
rain chart
and use the manual update there
I have already set the December rainfall, using the method you mention above, and as I stated in my original post ALL the WD data, graphs and charts show the correct value of 20.0mm.
I have double checked these and restarted WD, but the December figure on the “Last 12 months rainfall chart” on WDL is still showing zero.
How and when does WD transfer the “Last 12 months rainfall” data to WDL and is there a WD file I can check/edit to correct this or does WDL keep a separate record of the monthly figures to produce this chart?
Regards
Ray
Month end rolled over but still no month 12 rain data showing on WDL.
Any ideas would be appreciated. :lol:
Problem solved with updating to WDL v6.06
but there appears to be a problem with the new WDL graph for January this year only showing month figure and not the year figure - hence Februrary figure for year to date is wrong by the January figure (too low)
New problem can be seen at:-
and
http://www.monadh-ruadh.co.uk/WC/wclive.html
click on “Annual Rainfall”
Is anybody else getting the same result - if so I will report as a bug in WDL v6.06?
double check the values for each month undr view, rain chart
I have checked all the 2011 months and their year todate figures as requested above and they are ALL correct.
It is only the year todate (annual) figures showing on the WDL graph (v6.06) that are incorrect.
Regards
Ray
I have found that other sites running WDL v6.06 have the same issue so have raised issue in WDL v6.06 topic area
