Rain Data for 7 days and 30 days not as expected
The seven days and 30 days show wrong totals when importing data… it says we had 574.40 mm of rain in the last seven days and 1516.10 in the last 30 days… I am pretty sure the outside world is disagreeing with that.
mob.dayboro.au/logfiles/102024lg.txt
and the one for sept
mob.dayboro.au/logfiles/92024lg.txt
The data looks a bit odd as I am testing file creation from weewx, instead of WD. Still the the data should be the same… I might be missing something…
Are these files the ones you have created or from WD
either way I would say your rain is out by a factor of 10 too high so the last entry on the 102024lg should be 5.60 and 146.60 instead of 56.00 and 1466.00
I also notice in that file that the daily rain figure is always 0 even when the rainlastmin records
So if using WD what values are on the WD screen if using weewx what is the raw data showing
They are made by weewx, I moved away from wd, I have fixed the report has a wrong rounding… grrr. Not sure about the daily rain… will chase that down.
I been staring at it and never noticed it… thanks so much.
