Instead of a Rain Radar Block I am now using a Soil Moisture Block in its place.
If I use the small soil moisture block it comes with a nice graphic the large block only has text is there any way to get the graphic in the large block
The small blocks are for 1 moist sensor and an optional soil-temp sensor.
Adequate for most.
The normal block can cope with up to 8? soil moist with corresponding temp sensors.
In some user versions, the leaf-wetness sensor data is displayed also.
There are multiple user versions floating around, maybe you can find one on the stations-maps?
Thanks again for all your help
