PWSweather and Weather Display
I’m having a problem with Weather Display sending information to PWSweather.
I have the proper station ID entered along with my my API key, sent in test data with no luck, generated a new API Key and also restated Weather Display still no luck.
Bothe Weather Cloud and Weather Underground are getting the data fine. I have no idea what else the problem would be. The station setup that I’m using is Heavy Weather import WS2800 with “use currdat.lst for data source” and " every 5 second update"
Any Help would be great!
Larry
what shows in the sentpwsweather.txt file?
This is what the file is showing…
http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=3&action=updateraw&ID=KMABROCK5&PASSWORD=b644b31b&dateutc=2021-10-
30+02%3A37%3A44&winddir=068&windspeedmph=2.0&windgustmph=1.3&humidity=81&tempf=48.2&rainin=0.012&baromin=30.189&dewptf=42.6&indoortempf=71.6&indoorhumidity=54&weather=CLR&clouds=&dailyrainin=0.386&soiltempf=&soilmoisture=&leafwetness=0.0&softwaretype=WeatherDisplay%3A10.37S
1-10-
OK
I have no TXT file with that name.
sentpwsweather.txt
Larry
sentpwsdata.txt
Brian,
I think that I’m all set, I did not notice that the software was a older version, I did upload the newer version last night and all is well for now.
Larry :smiley:
