PWSWD is a block-based website template which allows you to configure which blocks are applicable to your website and data availability. It is available for the following weather data uploads:
- WDapi or clientraw.txt with WeatherDisplay
- clientraw.txt as used by Meteohub , WSWIN and others
- realtime.txt originally defined for Cumulus - now also used by Weewx, WeatherCat, WiFiLogger, WeatherLink, Meteobridge and others
- It can also be used for stations uploading Weatherlink.com both v1 and v2-API, WeatherUnderground , Ambient weather net or WeatherFlow
- It can also be used with Ecowitt “Custom upload”
