PWS - Header Banner image
I don’t suppose anyone has found a way that won’t destruct with the next update to include a banner image for the site?
I’d like to keep my image consistent with the rest of my site. I am thinking what I need is a URL for the image and a URL for clicking on the image (same as my Wordpress site) shame it isn’t easier to convert the whole PWS into a Wordpress template :slight_smile:
before.txt might work for you
  1. There is no “next update” planned. Only simple updates of one script if necessary.
  2. As @blainec pointed out, most banners a.s.o. are inserted in the pwsWD/_my_settings/before.txt file.
    That can be HTM java-scripts or PHP-code as the before.txt file is PHP included
<!--  $scrpt_vrsn_dt  = 'before.txt|01|2021-04-17';  # release 2012_lts
put a link to what you want to include at the empty line below
  1. If you post the URL to your pwsWD website and the “the rest of my site” it is easier to answer and help
You can insert the pwsWD in a wordpress site. More users are doing that.
The pwsWD page can also omit the headers / footers so that only the main dashboard is shown. The top-row small blocks can be removed also with just 1 setting.
Just tell us how you want to use the dashboard in your main-website?
Using standard inspect/edit html, I added a few lines to before.txt
<a href="https://mm0zif.radio/current/" rel="home" class="PWS_weather_container " itemprop="url">
<img src="https://mm0zif.radio/current/wp-content/uploads/2024/08/NewBanner.jpeg" alt="MM0ZIF Amateur Radio, and Weather Station" class="PWS_weather_item" style=" width: 100%;">
</a>
This is the result:
And it remains fully flexible
