PWS-Dashboard Maximum/Minimum Temperatures
Can someone help me figure out why my history.txt file is not updating? The content of the file is the same as during the installation. At the same time, I want to take the opportunity to express my thanks and respect for the fantastic work behind the software.
https://thorner.se
Are you running the station cron job? See 11_cron.pages
I tried to, but it failed on my uncertainity about the path to the cron job. This was my suggestion: `/usr/local/bin/php /home/nwvcpdkr/public_html/pwsWD/PWS_cron_stationcron.php. Make it sense to you? I’m so grateful for any help on this! Wish you a pleasant evening.
//Roland
I only tried running the stationcron job from Weather Display for a few days, but I remember I just used the URL: try
https://www.thorner.se/pwsWD/PWS_cron_stationcron.php
I am not the best person to advise you, you might find more help from a Forum search.
If you really want to use the cron-job from your hosting provider, you should ask them. Maybe there is a How_To document. There are multiple different hosting systems and the differences in How-To setup a cron job are difficult to spot.
A better solution:
→ Use a free external cron server such as
https://cron-job.org/en/
or
https://www.cronjob.de/.
With an external cron-server you only have to specify the frequency and to enter the correct full URL which @bitsostring also posted
Thank you!
I’m now using an external cron server. I guess it’s working even thoug I’m concerned about the results as they are presented. In the Max/min tile there’s data from November 22 where I can’t understand the origin.
All the best!
Roland
That is a GIGO problem.
The history data is kept in a file, and without frequent updates with a cron-job the data gets errors.
You can check the current history values in the “Nuvarande himmel” block with the “Historik” pop-up.
There is an update script to enter correct values once
pwsWD/PWS_hist_update.php?pw=XXXXXX
Replace XXXXXX with your easyweathersetup password.
Thank you!
This action did really matter. I will now go on with other challenges. BTW I’ve done updates in the SE-language textfile. Is anyone interested? In case let me know and I’ll publish a link.
//Roland
