PWS Dashboard - 3rd party Webcam Stream Install
Hi, I’m a newby to the site and to PWS Dashboard which I really like. I also only recently acquired a PWS so steep curve for me. (I use WD and WU)
In PWS I’m trying to add a webcam stream from a local site on the internet (【LIVE】 Webcam Ballito - South Africa | SkylineWebcams). They also offer a bunch of code for the particular webcam which I have no idea what to do with:-
【LIVE】 Ballito - South Africa | SkylineWebcams
Can anyone please assist. I am technically challenged but I can use Notepad++ if it’s just copy and paste.
Sorry, I realise the code I posted comes up on the site as the actual webcam. Not sure how to send the code without it displaying as a webcam.
Put three back ticks (```) on a line above and below your code. That should mark it as a code block to be displayed rather than acted on.
<a href="https://www.skylinewebcams.com/en/webcam/south-africa/kwazulu-natal/kwadukuza/ballito.html" target="_blank"><img src="https://embed.skylinewebcams.com/img/666.jpg" alt="【LIVE】 Ballito - South Africa | SkylineWebcams"></a>
Hope that works. Thanks,
Hi Stuart,
It is always speeds up answers if you post the link to your website.
I tested with the link you gave, but it will not work inside another website.
The only thing you get:
a small old image in the webcam block with the arrow
if a visitor clicks on it, the visitor goes to another website and leaves your website.
If you want that, I adapted the current webcam script and posted it here.
webcam_c_block.php.zip (2.2 KB)
If you are going to use it, you have to comment two lines in the script PWS_blocks.php to remove the “enlarge” text just below the image.
When adapting a script, Always make a copy of the script first . Copy it from the website to a local computer at home.
Script: PWS_blocks.php|01|2021-07-30
Lines 430-431 now read:
$blck_ppp [$script][]   = array ('show' => true,      'popup' => 'image_popup.php?nr=wcam1',            'chartinfo' => 'popup',    'text' => $cam_txt  );
$blck_ppp [$script][]   = array ('show' => false,     'popup' => '_my_settings/webfilm_popup.php',    'chartinfo' => 'popup',    'text' => $movie_txt  );=
Add a comment mark at the first position of each line. It should look like
# $blck_ppp [$script][]   = array ('show' => true,      'popup' => 'image_popup.php?nr=wcam1',            'chartinfo' => 'popup',    'text' => $cam_txt  );
# $blck_ppp [$script][]   = array ('show' => false,     'popup' => '_my_settings/webfilm_popup.php',    'chartinfo' => 'popup',    'text' => $movie_txt  );
Much pleasure with testing the PWS_Dashbnoard.
Thanks so much Wim. Really appreciated. I’m always humbled by the stuff I don’t know rather than what I think I know.
Best regards
Can you please not do a full download of PWS_Dashboard anymore?
3 full downloads in 2 days should be adequate for Stuart McArthur of www.sherwoodemm.com
The full download contains all versions for all continents.
Only one is needed, future updates will be on-line on a separate thread.
And please post the link to your pws-dashboard website in every request for support.
My apologies. I wanted to run a test site on my NAS and I thought I needed a fresh copy. Won’t happen again.
The site sherwoodemm.com is actually my business website which I operate through Wix. I plan to host my weather site on my home NAS but I want to sandbox it until it works properly. A day or so. Apologies again.
