After giving up on the free hosting site, I had problems getting the PWS_cron_stationcron to work when run from the cron scheduler of the new host site.
(The status check kept turning red)
It ran fine when I used the browser.
Here are the errors:
Warning: file(languages/lang_en.txt): failed to open stream: No such file or directory in /home2/beac01185xxx/public_html/pwsWD/PWS_settings.php on line 304
Warning: Invalid argument supplied for foreach() in /home2/beac01185xxx/public_html/pwsWD/PWS_settings.php on line 305
Warning: file_put_contents(./_my_settings/status.arr.tmp): failed to open stream: No such file or directory in /home2/beac01185xxx/public_html/pwsWD/PWS_load_files.php on line 56
My amateur fix was to change the following:
PWS_settings.php
line 304 changed else { $arr = file ('languages/lang_en.txt');
to else { $arr = file (__DIR__.'/languages/lang_en.txt');
Hi Bruce,
Sorry that you run into these two addressing errors.
Normally the provider cron-server should point to the executing folder correctly.
Which is the folder the PWS_cron_stationcron.php script is executed in. In your case pwsWD.
The websites I test with (3 different providers) did not had this problem you encountered when I tested in the past.
Would you be so kind to add to the cron setup?
→ . . . . /_test.php?test=PWS_cron_stationcron.php
I hope to get more errors.
@ ALL
As PWS_Dashboard only uses 1 cron, try to use an external cron-provider such as
Wim,
I had to use cron-job.org to get the _test.php?test=PWS_cron_stationcron.php to run.
Evidently the provider cron-server doesn’t let you use the “?” in the URL.
I found this out when I tried to redirect the output of "PWS_cron_stationcron.php?test " during my hunt for the red status check problem.
Bruce
The only errors I got today occurred when moving a complete “pwsWD” folder to another webserver.
One has to run PWS_easyweathersetup.php to get the file locations correct.
Also one has to delete the . . ./pwsWD/_my_settings/status.arr.
That file has the full folder list from the previous server. Example
I did not get your errors, but those are genuine so I will update the scripts accordingly.
Can you please use in the cron setting this small script?
It loads the PWS_cron_stationcron.php after setting the error messaging correctly.
Just once / day and select in cPanel an email with the messages.
I hope to catch other warnings/errors that way.
