PWD says offline, but data are updating from my Davis VP2
Recently upgraded my WeeWX to v5.0.1-4
Any suggestions to what can be causing this?
Hi GW400,
As far as I can see your realtime.txt shows a data time which is
1 hour off your dashboard time
Maybe WEEWX is 1 hour off?
As you are using …/realtime/ to address the realtime.txt file, I do not know the correct URL to that file to check if the dashboard scripts access the correct file.
Dashboard debug scripts can not access files outside the “pwsWD” folder.
But when using the debug dashboard I assume the data displayed by the buttons “Show station values” and “Live data values” is the correct data to use.
Check these links
Data file …/realtime/.realtime.txt
Data processed in the weather array
Or the attached screenshot
I checked your other site, there the realtime.txt date/time fields are correct with the date-time displayed on the dashboard top-left block .
Spot on Wim!
Time zone setting was one hour off.
Thank you very much!
Regards
Kjell Inge
