I have had Purple Air running without issue for maybe 6 months. Upgraded to 10.37S139 a couple of weeks ago. I noticed a few days ago that the Purple Air AQI reading had flatlined, but the AQ VOC reading was still showing in WD. The Purple Air map was being updated properly. I went back to build 125, but nothing changed. As of now the AQI reading is 0.0 and the AQ VOC is 267. The Purple Air map is carrying the correct reading of 56 and 267. Attached is a screenshot of the settings and the error message after pushing test… I have been working on this for 2 days, so time to ask for help.
my observation on this are
1 enable the purpleair api
2 put the sensor number in
3 go to https://api.purpleair.com for api keys
4 update WD to latest build 140 which is dated 30th May
then test
PurpleAir has changed their API and some programming changes need to be made in Weather Display software to make this work again. We will have to wait for the developer of WD to make these changes.
