Problem with wunderground upload
It *would* be nice to have a laundry list of things of features that are not "enabled" in the Linux version (or broken.) I for one have spent a lot of time trying to implement program features that are unavailable in the Linux version.
Just everyone make sure you are using version 3.0 :!:
Chris - I tried a couple of times (on two different machines) to download your 2.4b file, but the download quits (stops) every time after about 8 Mbyte. Gunzip reports unexpected end of file. The 2.2 file size is about 15 Mbyte. What is the size of the 2.4b file on your box?
Maybe your 2.4b file is a corrupted download from the wd?
–John
nope, that is the correct size. That is why you have to install 2.2 first because 2.4 doesn’t have everthing you need. However, 2.4 does have the stuff you need to run version 3.0
Brian, the FTP logs above (Page 1) were made by clicking the manual upload button, and if you check the FTP logs above you will see that the ftp connects, the server answers “have fun etc.” and is ready to transfer files, (so we are talking TCPIP) and there is one thing to do, then there is nothing to do, but nothing happens. Is there an error log, what shows what happened??? Can you tell me what can cause this?
                                                   Thanks, Bob
I learned how to check my station’s upload to wunderground and no data is there (KFLDELAND1)
–John
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KFLDELAN1
Boy do I have egg on my face :frowning:
My station’s name is KFDELAN1
It is not KFDELAND1
The upload does work! :slight_smile:
Bob - yours should work if mine works.
–John
