Hehe FishDude!
If I would only have got an error message …
Well I just tried your way and it’s working fine.
Thank you all for the help, this is most appreciated.
Now I wonder if I could run Wdisplay on my old box … an old 64 cpu’s Pentium Pro I will give it a try later tonight.
By the way this old box is a file server with an attached cluster 382.2 TB on a 8 channel Raid array (raid 5).
Glad you got it figured out. After getting so much help form folks here, I am glad I could help someone else out for a change!
That old server will surely handle WD fine, LOL! Not sure how many years it would take collecting weather data to fill up 382 TB! LOL!
windy2
23
so, what was the majic trick in the end?
the server system path ?
Yep!
the server system path did the trick.
Good work fishdude :cheers:
windy2
26
yes, good work fishdude
maybe this could be put into the FAQ
(although its not very frequently asked)
Glad I could help, glad too after all the help I have gotten around here.
Sometimes All the Microsoft brainwashing pays off…
For sure this should go to the FAQ’S files…
Many thanks again,
