Problem With Temperature Reading with APRS Lite Version
Hello To All,
I’m new to the community and the Weather Watch software. I have the La Crosse 2010 weather station and the 2010-13 data logger/PC interface. I’m getting the right temperature readings on the main LCD console from the inside and outside wireless temperature/humidity sensors.
But the 2010-13 logger is sending temperature, humidity and dewpoint data to the Weather Watch software that’s incorrect. I have the APRS lite v8 and am also trying out the v10+ demo and the temperature, humidity and dewpoint readings are all wrong.
I’m not sure if the logger has a problem which I doubt because the wind speed/direction and barometric pressure readings are correct or if I’m overlooking an adjustment within the software. Temperatures are running approximately 45 deg. F to low.
Any help would be much appreciated. BTW this is a CWOP station #CW2111.
i think i might have covered this on another thread…
but, have you set the outdoor sensor number to use (i.e say 1 ), in the ws2010-13/ws2500 data setup and info screen?
try that
also, what is the raw barometer reported in that screen?
