Problem with extra sensors WMR928NX in latest version [RESOLVED]
When i installed the latest version (10.37Qb38), all my extra sensors (only temperature sensors and i have 3) shows the value zero (0) in the application.
Rolling back to my previous version (10.37Qb35) solves the problem.
My server is running Windows Server 2008R2 sp1, an my station is Oregon Scientific WMR928NX.
Tobias, Sweden
use this update
http://www.weather-display.com/downloadfiles/WeatherDnewcompilerwmr968.zip
then go to setup, advanced/misc
tick
log the raw data
then post here the raw data that shows for the temperature only sensor data
under view, WS2010/WS2500
so that I can get the CRC error checking working for that sensor data
(I changed the way I was working with that CRC error checking (the way I was doing it was not ideal))
thanks
Has anyone else had this problem or has Brian sorted it out? I do not want to upgrade to the latest version if there is still a problem as I have three extra sensors running.
Bob
it only affects temperature only sensors
and I am needed feedback to be able to fix it
(try a new normal update or the above link to see if its fixed)
this is OK now in the latest update
I can only say that my extra sensors, modified for sunshine and black bulb, are and have worked fine. they are the Temp and hum sensors so that may not be too much help, but the install did not cause any problems at all.
I should mention that periodically mine do stop reporting to the console and this in turn leaves the value in WD on the last one that was recorded. The lack of reporting may be due to many things including rain between sensor and console.
Best wishes
Mike
