Problem with 5 day NOAA forecast
Below is a copy of the ftp log file.
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (76,162,49,132,204,84).
STOR tmp
150 Opening ASCII mode data connection for tmp
226 Transfer complete.
File uploaded at time :8:37:21
RNFR tmp
350 File or directory exists, ready for destination name.
RNTO
501 Invalid number of arguments.
141: 501 Invalid number of arguments.
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (76,162,49,132,204,85).
STOR tmp
File uploaded at time :8:37:26
RNFR tmp
RNTO
My web page’s forecast is basically blank except it does show the time and date when the forecast was created. It seems to be up to date. I have checked with my internet host and they claim all is well. The rest of my page downloads normally including warnings. Now if I turn the overides switch to “off”, I get a report on the web site that includes a NOAA report for current conditions in all of California. I am using tgftp and the zone I want is caz069. Perhaps someone would try that and see what you get so I can try to isolate the problem.
Thank you for any help or suggestions.
I’m having the exact same problem. At first, the forecasts weren’t updating (just kept displaying the old one from Jan 22). I changed the ftp server address (now “tgftp.nws.noaa.gov”) and started getting updated NOAA reports again. Now they don’t show up on the web page (override on/off has no affect on this for me). I’m using wxlocal.html with few changes but it has always worked.
Does any one know if the format of the 5-day forecast file changed?
Mine gets overwritten each time, I no longer have an old one from before the address change. If true, this may explain why the tag names don’t work (i.e., “%5dayforecastdayday1%”).
Check your download directory and see if your zone file is up to date. Also, any errors in the ftp log?
Should have read the other post first: NOAA 5 day forecast download -> you need to change the ftp server in use
Upgraded to 10.37a and it works fine now :lol:
Update:
All is back to normal EXCEPT, the 1st day of the 5-day forecast (i.e. “Today” or “Tonight”) is not bold, not all caps and not on a line by itself like it used to be, and like all the other days are. Forecast now starts with a line that has 3 dashes (—). So, now it looks like this:
Tonight Mostly Cloudy…
But it used to look like this:
TONIGHT
Mostly Coudy…
Probably due to another change in the format, but I can live with this – just wanted you to know.
Another Update:
Nevermind all that – after my web site updated a 2nd time, it all looks right again – I really should be more patient, huh?
No problem downloading correct ftp file (in this case COZ040.txt), and WD five day forecast is pointed to that file, but format has changed so that WD can’t read the 5 day forecast. Here’s what I’m getting from the ftp site. It has the right info in it, but for more locations than before January 21st or so format. All available files in the directory have exactly the same format. I’m just interested in the Northeast Colorado/Denver info… Any suggestions?
Ed…
Expires:200704081200;;189328
FPUS65 KBOU 072200
SFTCO
COZALL-081200-
TABULAR STATE FORECAST FOR COLORADO
NATIONAL WEATHER SERVICE DENVER CO
400 PM MDT SAT APR 7 2007
ROWS INCLUDE…
DAILY PREDOMINANT DAYTIME WEATHER 6AM-6PM
FORECAST TEMPERATURES…EARLY MORNING LOW/DAYTIME HIGH
PROBABILITY OF PRECIPITATION NIGHTTIME 6PM-6AM/DAYTIME 6AM-6PM
- INDICATES TEMPERATURES BELOW ZERO
MM INDICATES MISSING DATA
FCST FCST FCST FCST FCST FCST FCST
SUN MON TUE WED THU FRI SAT
APR 08 APR 09 APR 10 APR 11 APR 12 APR 13 APR 14
…NORTHEAST COLORADO…
DENVER
MOCLDY PTCLDY PTCLDY PTCLDY PTCLDY MOCLDY PTCLDY
20/42 34/67 37/54 31/64 37/67 33/45 31/53
60/20 20/20 20/10 10/00 10/10 30/40 20/10
BURLINGTON
PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY
16/41 26/64 35/57 31/58 35/61 39/55 30/55
20/10 00/00 20/20 10/10 10/10 20/30 30/10
…SOUTHEAST COLORADO…
COLORADO SPRINGS
FZDRZL PTCLDY PTCLDY PTCLDY PTCLDY MOCLDY PTCLDY
23/45 34/58 36/56 30/57 35/62 32/47 28/53
60/40 10/10 20/10 10/00 10/20 30/30 20/10
PUEBLO
FLRRYS PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY
27/47 34/66 39/64 34/65 39/70 36/54 32/61
60/30 10/00 20/10 10/00 10/10 20/20 10/10
ALAMOSA
MOCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY SUNNY
31/55 25/62 30/55 25/61 30/57 26/51 25/57
50/20 10/10 20/10 10/00 00/10 20/20 10/10
…WESTERN COLORADO…
CRAIG
29/59 31/61 31/46 24/57 26/63 28/51 28/51
10/30 30/20 10/10 00/10 20/30 30/20 20/10
GRAND JUNCTION
TSTRMS PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY
44/65 43/67 44/56 39/68 41/66 37/61 37/61
20/50 50/10 10/10 00/00 10/20 20/10 10/10
DURANGO
MOCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY PTCLDY
39/59 39/64 37/58 31/60 31/65 25/61 25/61
40/40 40/20 20/10 00/00 10/30 20/20 10/10
I think you’re looking in the wrong place. Try: data/forecasts/zone/co for the directory in WD, then coz050.txt. That will get you to the zone forecast rather than the cities forecasts.
Had tried that earlier. (Actually COZ040.txt for the data I want; COZ050.txt doesn’t work either). 5 day forecast window shows location across the top, but no data…
hmmm - just tried that path here: tgftp.nws.noaa.gov/data/forecasts/co, then I chose coz040.txt. Here’s what it gave me:
Expires:200704101100;;239512
FPUS55 KBOU 092111
ZFPBOU
ZONE FORECASTS FOR NORTHEAST AND NORTH CENTRAL COLORADO
311 PM MDT MON APR 09 2007
COZ038>040-101100-
LARIMER COUNTY BELOW 6000 FEET/NORTHWEST WELD COUNTY-BOULDER AND
JEFFERSON COUNTIES BELOW 6000 FEET/WEST BROOMFIELD COUNTY-NORTH
DOUGLAS COUNTY BELOW 6000 FEET/DENVER/WEST ADAMS AND ARAPAHOE
COUNTIES/EAST BROOMFIELD COUNTY-
INCLUDING FORT COLLINS…HEREFORD…LOVELAND…NUNN…ARVADA…
BOULDER…GOLDEN…LAKEWOOD…LONGMONT…AURORA…BRIGHTON…CITY
OF DENVER…DENVER INTERNATIONAL AIRPORT…HIGHLANDS RANCH…
LITTLETON…PARKER
.TONIGHT…MOSTLY CLOUDY. A 10 PERCENT CHANCE OF RAIN SHOWERS IN
THE EVENING. LOWS IN THE MID 30S. SOUTHWEST WINDS 10 TO 15 MPH IN THE
EVENING BECOMING LIGHT.
.TUESDAY…PARTLY SUNNY WITH A SLIGHT CHANCE OF RAIN SHOWERS. ISOLATED
THUNDERSTORMS POSSIBLE IN THE AFTERNOON. HIGHS IN THE LOWER 50S.
NORTH WINDS 15 TO 25 MPH. CHANCE OF PRECIPITATION 20 PERCENT.
.TUESDAY NIGHT…PARTLY CLOUDY WITH A 10 PERCENT CHANCE OF RAIN
SHOWERS. LOWS 26 TO 32. NORTHWEST WINDS 15 TO 25 MPH.
.WEDNESDAY…PARTLY SUNNY. HIGHS 51 TO 57.
.WEDNESDAY NIGHT…MOSTLY CLOUDY IN THE EVENING THEN BECOMING
PARTLY CLOUDY. A 20 PERCENT CHANCE OF RAIN SHOWERS. LOWS IN THE
LOWER 30S.
.THURSDAY AND THURSDAY NIGHT…MOSTLY CLOUDY. CHANCE OF SNOW AND
SLIGHT CHANCE OF THUNDERSTORMS. HIGHS IN THE UPPER 40S. LOWS IN
THE LOWER 30S. CHANCE OF PRECIPITATION 40 PERCENT.
.FRIDAY AND FRIDAY NIGHT…MOSTLY CLOUDY WITH A 40 PERCENT CHANCE
OF SNOW. WINDY. HIGHS IN THE UPPER 30S. LOWS IN THE UPPER 20S.
.SATURDAY AND SATURDAY NIGHT…PARTLY CLOUDY. HIGHS AROUND 50.
LOWS IN THE LOWER 30S.
.SUNDAY AND SUNDAY NIGHT…PARTLY CLOUDY. HIGHS AROUND 60. LOWS IN
THE MID 30S.
.MONDAY…PARTLY SUNNY WITH A 20 PERCENT CHANCE OF RAIN AND SNOW.
HIGHS IN THE UPPER 50S.
I haven’t made myself clear. Yes, I get the same data you show, no problem. I’m not saying there is a problem with the NOAA weather web site. What doesn’t work is displaying that data in the WD 5 day forecast window as set up in the “NOAA forecast download” page under FTP/Internet setup. The format sent by NOAA changed in late January and the WD 5 day forecast window has not worked since. That’s why I’ve been trying several of the NOAA pages to see if one of the formats works. So far, none work in displaying the 5 day forcast data in the WD 5 day forecase window.
Ed
Ed what version of WD as Brian updated it just for this issue some time ago…
Running 10.37d. Yes, I know there have been prior postings that the problem was fixed, but I don’t see it as being fixed. I’ve attached two screen shots so you can see what I see.
http://216.247.122.31/setup_screen.jpg
http://216.247.122.31/5-day_screen.jpg
Ed
Don’t know if it makes a difference but the actual file name is in lower cASeon the NOAA server… coz040.txt
Bob:
Makes no difference, I tried it both ways. The correct current file is downloaded as scheduled with no problem. For some reason WD can’t read the file and show the data in the WD 5 day forecast window. Any other thoughts?
Thanks for your suggestions.
Ed
Ed,
I was going to take another look at your setup screen but for some reason it won’t display for me again…
Have you double checked the actual 5 day setup options to make sure it is still set properly?
Otherwise I am at a loss cause mine has been working without any problems since Brian updated WD and I changed addresses.
http://jaxweather.net/WeatherImages/WD/forecast5day.gif
Also you might want to try resetting the 5day to “Use NWS”. See enclosed screenshot:
I also would check and make sure the downloaded file is actually going to your main directory and not somewhere else as the file you have selected to use appears to indicate you are downloading to the main directory.
Maybe change the download to somewhere else like metars or download and then after it is downloaded set the file to use to the new location…
My 2 cents Do a search for coz040.txt and see if it is in the same file that the 5-day points to. (C:\Program File\wdisplay\downloads\coz040) or something like that. You files do not match.
The file is where it is supposed to be. There is only one file, no duplicates, and all in the main WD directory where the 5 day forecast setting is pointing. Also, I had previously tried the USE NWS setting with no change.
As a last resort, I uninstalled WD and reinstalled. Whatever that did fixed the problem. All the settings after reinstall are exactly the same as before, but now it works. Obviously something was “stuck” somewhere, and now isn’t, but i have no clue as to what that might have been. I’ve been screwing around with this for a week.
I appreciate all the help, even though I don’t think we’ve really learned anything in the process! As I noted earlier, there were times at which I would get the first line of the forecast file, indicating for sure that WD was pointed to the right file. Even the download time showed correctly. All that didn’t show was the weather data, and now that’s back.
Thanks, all again.
Ed Bettinardi
