Hi:
I had my weather W11 PC down for several hours to upgrade memory and run memtest98. WD v1037S build 143. I have spent most of the day thrashing about trying to load the missing data from the VP2 USB logger. I have had to restore the datafiles and logfiles from the backup several times, which fortunately was taken right before I began the memory modifications. I need to figure this out because W11 will update and reboot automatically and it cannot restart WD in administrator mode until I authorize it.
The last valid entry in 72022lg.txt was 7:55. I am doing the following:
- Control Panel / Data Logger - set “Time/Date to Get The Data From” to 7:56 and click [Set]
- Shutdown WD
[li]Edit these log files to remove entries later than 7:55
72022lg.txt
72022extralog.txt
72022vantagelog.txt[/li] - Restart WD
- Log Loading dialog shows loading data starting at 17:45
- Action / Convert Log files To Data Files
The data in the log files jumps from 7:55 to 17:45 and so do the graphs.
It did not download 7:56 to 17:44
Once, while I was thrashing around, it did download all the data, but I don’t know why.
Any advice is apreciated,
Steve
