Something that some people might not realize is that it is possible to have a web page that points elsewhere for the WDLive portion of the content.
I have recently been playing around with my weather web pages and created a web page that is on my primary server, where the WDLive portion is actually hosted on a different server with better bandwidth.
In the section that most people see in the html example:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0" WIDTH="100%" HEIGHT="100%" id="wdlv3_01.swf" ALIGN>
<param NAME="movie" VALUE="wdlv3_01.swf?http://www.sample.com/wxlive/wdlconfig.xml">
<param NAME="quality" VALUE="High">
<param NAME="wmode" VALUE="Opaque">
<param NAME="bgcolor" VALUE="B9E9FF">
<param name="_cx" value="17621">
<param name="_cy" value="10425">
<param name="FlashVars" value>
<param name="Src" value="wdlv3_01.swf?http://www.sample.com/wxlive/wdlconfig.xml">
<param name="Play" value="0">
<param name="Loop" value="-1">
<param name="SAlign" value>
<param name="Menu" value="0">
<param name="Base" value>
<param name="AllowScriptAccess" value="always">
<param name="Scale" value="ShowAll">
<param name="DeviceFont" value="0">
<param name="EmbedMovie" value="0">
<param name="SWRemote" value>
<param name="MovieData" value>
<param name="SeamlessTabbing" value="1">
<EMBED src="wdlv3_01.swf?http://www.sample.com/wxlive/wdlconfig.xml" quality=high bgcolor=#FFFFFF WIDTH="100%" HEIGHT="100%" NAME="wdlv3_01.swf" ALIGN="" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"> </EMBED></object>
You can source a remote location of where the actual flash file is located with the data.
<param name="Src" value="http://sample.com/wxlive/wdlv3_01.swf?http://www.sample.com/wxlive/wdlconfig.xml">
Same line with a slight difference. The top line assumes the Flash file is local to the page you are loading. It does say exactly where the wdlconf.xml file is, but the wdlv3_01.swf needs to be local.
In the second, line, the data and the flash file are both referenced… so the html file containing this could actually be on a completely different server and path.
A sample of this is my flash page
http://www.tnet.com/weather-live.php
This is on my primary corporate server, but the source and location of the WDLive is actually on another hosted server with a completely different domain. the WDL is registerd in the remote servers domain.
The next step is to do some browser type idenfication and use different settings to get the best looking display depending on if the user is using MSIE or Firefox.
