Does anyone have software for the organ scientific WMR89 it is not available for the vendor?? Don’t know why. Bought the unit from Italy Thanks Archie I am replacing an older wmr968 i have had for about 15 yrs
weather display does support this station
however you still might need the original software installed to setup the usb port driver
I have just recently purchased the OS WMR89. I am having problems getting this device to connect to PC, (WIN 10), via USB. At first it appeared to be recognised and installed then it comes up on device manager as no driver installed with the yellow exclamation mark. I found on this site there maybe issues with driver signature and tried the method to disable driver signature enforcement. Still no result. I have tried connecting to another PC running Win 7, still no connection. Has anyone solved this? Cheers.
have you installed and tried the software that comes with the station first
Hi Brian, thanks for the reply. No software came with the Weather Station. I have been searching the web for solutions and keep hitting dead ends. The supplier I bought the WS from, Instrument Choice here in Australia are tryin find solution. It appears I need a file called wmr89_installer_v1.19(win 10).zip but the link to this software Oregon Scientific has on the Net does not work. Does anyone on this Forum have this file? I’ll be so disappointed if this station cannot now do what the manufacturer claims as it is within my budget and the sensors are working fine to the Base Station.
Thanks Brian,
You always come to the Party with solutions. I have installed the software and the WMR89 is connected and worked on the Weather software supplied from Oregon. I have closed that application and opened Weather Display. This is not receiving data. I have selected WMR89 USB in station setup. Is there something else I need to do, is there something in background with OS Weather application that is stopping connection to WD? Cheers.
As per my recent email I have WD going with WMR89. In Station setup, although USB connection I changed selected COM1 Port to COM3.
Cheers
